- Thank you received: 2
size of vacuum plug?
- diamond
16 Oct 2017 11:51 #773063
by diamond
Current bikes- 2010 HD street glide,2004 zrx1200r, 2001 wr290x,84 nija900A1 , 83kz750L3, mz250f.
Previously Enjoyed- 77 Kh400, 83 kdx175, 81 kz550, 84 ninja 900, 92 gsxr750, 2000 gsxr600, 02 R1,
01 yz250, 03 yz125, 06 R6, 00 cr125, 85 ninja 900, 07 Victory Jackpot, 83,84,89 RZ350,2006 rmz250
size of vacuum plug? was created by diamond
83 kz750L3 missing one plug I just don't know what size to order? 4,5,6mm 1/4, 5/32????// Thanks in advance.
- Thank you received: 2829
16 Oct 2017 14:48 #773069
by 650ed
Replied by 650ed on topic size of vacuum plug?
Take a look at the link below. When you get to it click on "Select Assembly" and use that to find the parts diagram for the part in question. That will then enable you to identify exactly which part you need and what the Kawasaki part number is. Using that information will make finding the correct part much easier. Ed
www.powersportswarehouse.com/p/Kawasaki#/s/KUS/kz750-l3//1/
The following user(s) said Thank You: diamond
- Thank you received: 1656
16 Oct 2017 16:30 #773076
by martin_csr
Replied by martin_csr on topic size of vacuum plug?
The vacuum ports are typically 1/4". The vac plugs for the 750-L3 are listed at Partzilla as 12x25, which probably means 12mm OD & 25mm L & the ID is probably around 6mm.
- diamond
17 Oct 2017 11:13 #773139
by diamond
Replied by diamond on topic size of vacuum plug?
Thank you lads.
