- Thank you received: 2
Tuning
- Swedez500
26 Sep 2017 09:51 - 26 Sep 2017 10:44 #771724
by Swedez500
Tuning was created by Swedez500
Hi there folks! Anyone with experience from rejetting teikei carburetors tk22 on a z500b3 1981?
Ive dropped the airbox and installed 4 individual airfilters and Need to size up needles for more fuel. What size is recommended?
Todays sizes: main jet #90, needle jet V#90, pilot jet #32.
Have a niiiice day!
Have a niiiice day!
Last edit: 26 Sep 2017 10:44 by Swedez500.
- loudhvx
- Thank you received: 1616
26 Sep 2017 13:51 #771735
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Tuning
You probably don't have to replace the needles, just shim them properly. I would start with a .5 to .6mm shim, but collect as many different thicknesses as you can.
s3.amazonaws.com/gpzweb/TK22mainPage/TK2...shimmingNeedles.html
The last time I jetted a Tk22 Kz550 for pods, we found we could just use all stock jets and shim the needle. This was with a pretty restrictive exhaust, though. It's not perfectly ideal, but runs perfect. The only downside is that the cruising fuel economy is not the greatest. The upside is that it comes off choke sooner so is easier to ride in cold weather.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: Swedez500, blackumi
- Swedez500
15 Oct 2017 03:02 #772973
by Swedez500
Replied by Swedez500 on topic Tuning
Thanx! Exactly what Im going to do as I now have 2 sets of original jets. Start shimming bigger and bigger until it works properly....
