- Thank you received: 4
$40 petcock on Amazon/eBay?
- BarnyardCoral
20 Sep 2017 16:21 - 20 Sep 2017 16:22 #771321
by BarnyardCoral
Grand Forks, ND
1981 KZ1000 CSR
"Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba...." - HST
$40 petcock on Amazon/eBay? was created by BarnyardCoral
I need to buy a new vacuum petcock since my rebuild didn't completely stop the petcock from leaking on the ON setting. The kit did indeed make a huge difference since it previously didn't stop any fuel from pouring out, but it's still seeping out. That said, has anyone bought or had experience with these $35-40 petcocks on Amazon or eBay? Here's the link:
www.amazon.com/dp/B01N9HA4M3/ref=cm_sw_r_cp_apa_QCVWzb05PTWF9
I could use the opinions of the B&B here.
Grand Forks, ND
1981 KZ1000 CSR
Last edit: 20 Sep 2017 16:22 by BarnyardCoral.
- Thank you received: 2236
21 Sep 2017 04:48 #771340
by TexasKZ
Replied by TexasKZ on topic $40 petcock on Amazon/eBay?
I have not used one of those, but one crucial step that many folks skip during a rebuild is carefully polishing the seat where the tiny oring is supposed to seal against, and the face of the lever that is supposed to seal against the smiley-faced oring. A tiny rough spot caused by a tiny bit of corrosion or hard debris can cause seepage. A little time, a micro fiber towel and some high quality aluminum polish can make a noticeable difference.
If the face of the lever is noticeably pitted or rough, you may need to start with some 800 or 1000 grit sandpaper taped to a piece of glass. Keep the area of the paper that you will be rubbing the valve face on wet with Wd40. This will keep the paper from getting clogged, and will reduce the chance of stuff being sanded off from getting embedded in the face of the lever.
- Thank you received: 1656
21 Sep 2017 05:45 - 21 Sep 2017 06:38 #771341
by martin_csr
Replied by martin_csr on topic $40 petcock on Amazon/eBay?
What rebuild kit did you try? The oem diaphragm assy & tap gasket are still available from the dealer.
When I rebuilt mine, I did as TexasKZ mentioned & polished the mating surfaces with brass wool.
As for that aftermarket petcock, it's listed as 34mm. What's the bolt hole spacing on your fuel tank?
An oem 51023-1375 petcock might be 44mm. It has a larger/wider fuel screen than the 34mm petcock & i know for sure it uses a larger petcock body o-ring where it contacts the tank. so this leads me to surmise that the spacing would be 44mm.
edit: at Z1Enterprises.com the oem 51023-1375 petcock is listed as 44mm.
Last edit: 21 Sep 2017 06:38 by martin_csr.
- davido
- Thank you received: 292
21 Sep 2017 11:36 #771360
by davido
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Replied by davido on topic $40 petcock on Amazon/eBay?
Ive fitted 2 rebuild kits in mine and its still pissing fuel out.I also followed this tutorial;
www.xs650.com/threads/rebuilding-yamaha-...lves-petcocks.20662/
which I found very informative. (Not so much now as the photos have disappeared). Ill be doing it again soon,as Im off the road til its sorted. Very frustrating.
Someone suggested (as a cowboy fix) to fit a basic on/off tap further down the fuel line. It wont work for me as there is no space to get my fingers in to operate it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
