Float height, drain spigot?
- whitskz
05 Sep 2017 07:16 #770376
by whitskz
Float height, drain spigot? was created by whitskz
78 kz1000, vm26. I read all the time about people making or buying a special tool for setting wet float height. Couldn't I just stick a tube on the drain spigot and open the drain a little? That would cost about zero dollars, don't see any mention of that so what am I missing?
- Thank you received: 1656
05 Sep 2017 07:20 #770377
by martin_csr
Replied by martin_csr on topic Float height, drain spigot?
If it works, then yes you can do it that way. Some guys use a vacuum fitting from the auto parts store, and either cut threads on it or just screw it into the drain hole. then attach clear tubing.
- Thank you received: 2838
05 Sep 2017 07:34 #770379
by Nessism
Replied by Nessism on topic Float height, drain spigot?
A piece of soft/clear plastic tubing with a taper shape ground in on one end can be used. Jam it into the threaded hole in the floatbowl and sort of screw it in as tightly as possible. Works fine.
- KZB2 650
- Thank you received: 265
05 Sep 2017 08:18 #770381
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic Float height, drain spigot?
I used #2 rubber corks and drilled a 3/8 hole in them for the hose when I set the floats on the 29s. Didn't leak a drop.
1978 KZ650 b-2
- kevski
- Thank you received: 157
05 Sep 2017 12:43 #770392
by kevski
Replied by kevski on topic Float height, drain spigot?
There are no drain spigots on vm26's, i made my own tool but it can be done as the other posters have said.
