- Thank you received: 1
Kz750 csr carb issues
- Backwoods_biker
24 Aug 2017 10:42 #769649
by Backwoods_biker
Kz750 csr carb issues was created by Backwoods_biker
Alright so I had a problem where my throttle was very sluggish trying to ride and it was very jerky when riding until very high rpms and I now have mufflers on it and still the same pod filters but it's still doing it now matter how I adjust the carbs so any help would be great!!!
- M_a_t_t
- Thank you received: 41
25 Aug 2017 19:51 #769762
by M_a_t_t
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Replied by M_a_t_t on topic Kz750 csr carb issues
Im still pretty new to bikes, but from what I've read on here you should start with maintenance things first. It has also been mentioned that sometimes what might seem like carb problems can be out of spec valve adjustments. Maybe consider getting a color tune. It is basically a glass that goes into a spark plug hole and lets you see inside the combustion chamber and tell if your lean, rich, or good. Hopefully someone with more knowledge will come along. (also BUMP)
Often there is a trouble shooting section in the FSM (factory service manual). It can be a good place to see if there is something un carb related that can affect it.
Good luck, Matt
Good luck, Matt
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
