Trouble staring after servicing carb floats
  • rich1ll1
  • rich1ll1's Avatar Topic Author
05 Aug 2017 12:44
#768399
Yesterday morning I let my bike warm up for a few minutes before work with the choke on. Lo and behold, I come out and my carbs are dripping gasoline from the right side overflow port and through the gasket of the float bowl itself. Today I lowered the carbs, cleaned out the float bowls, and replaced the gaskets, floats, and the small attached spring. The floats are now identical in placement and dry height. After buttoning everything back together, the bike wouldn't start at all. I was careful not to mess with anything on the carbs themselves other than the float bowls/floats and I double checked the fuel lines etc. to make sure I didn't leave something out. I'm not sure where to start troubleshooting, any ideas?? The carbs are original equipment Keihin CV, although it does seem that an attempt was made at removing the jets at one point.
82' Belt Driven KZ440
  • martin_csr
  • martin_csr's Avatar
Re: Trouble staring after servicing carb floats
05 Aug 2017 14:42 - 05 Aug 2017 14:59
#768401
Service fuel level check. Try checking the fuel level wet by using clear tubing.
Sometimes setting the floats dry doesn't result in a correct fuel level.
The manual may describe how to do the test.
Last edit: 05 Aug 2017 14:59 by martin_csr.
The following user(s) said Thank You: rich1ll1
  • mopguy
  • mopguy's Avatar
05 Aug 2017 15:36
#768403
Do a search here for clear tube test method and also go to the top and click on ARTICLES and click on Technical Tips and read Carb Cleaning 101 & 102., THIS SHOULD HELP YOU DO THE JOB PROPERLY, if you get stuck chime in and someone will help along.
The following user(s) said Thank You: GPz550D1, rich1ll1
  • rich1ll1
06 Aug 2017 08:22
#768439
I was able to rule out any issue with the float bowls last night thanks to the "clear tube" test. The bike still wouldn't start so I left it alone. This morning I put some fresh eyes on the bike and did an inventory of air, fuel, and spark. Turns out, an unrelated spark issue was to blame for the failed firing. Thanks to mopguy and martin_csr for helping me rule out the fuel level in the float bowls. Next I want to find a reliable replacement for the equipped ignition wires (screw-in boot) and maybe get something new for the coil. Thanks again, I hadn't ridden since my Thursday commute!
  • Hyde_me
  • Hyde_me's Avatar
06 Aug 2017 10:49
#768449
I replaced my wires by getting a few feet of 7mm wire and new boots. I could not find a place that could make the press on boots but if I put the wires on right and don't over tighten them the work great.
07 Aug 2017 05:27 - 07 Aug 2017 05:28
#768503
Z1E offers the Dyna plug wires in different versions and colors.
Dyna plug wires come with integrated non-resistant caps, which I prefer and have used trouble-free for many years. The caps may of course be snipped off and replaced with whatever caps might otherwise be preferred.
Stock Kaw Z1 and KZ900/1000 came with non-resistant solid metal core plug wires,non-resistant (non-R NGKB8ES spark plugs and resistor caps (to lessen audio interference).
Click here > www.z1enterprises.com/dyna-ignition-wire...pper-core-black.html
Good Fortune! :)
Last edit: 07 Aug 2017 05:28 by Patton.
  • rich1ll1
07 Aug 2017 11:04
#768515
Ordered along with a new coil pack!
