Selecting a jet needle
  • kyan44
  • kyan44's Avatar Topic Author
27 Jul 2017 15:07
#767844
Hello guys! My carbs are running lean on 1/4 to 3/4 throttle. I have a:
jet needle: #6F5 on #4.
How do I know which needle to get to make the carbs run richer.? Any suggestions?
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Selecting a jet needle
27 Jul 2017 17:56
#767851
Download the Sudco catalog.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • KZB2 650
  • KZB2 650's Avatar
27 Jul 2017 18:32
#767855
Maybe save the money and time and try the 5th clip..... I went from the 4th to the 5th groove on my 24s before I went with my 29s and it seemed to go good.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 Jul 2017 21:26 - 27 Jul 2017 21:27
#767859
The needles are for fine adjustments. They run best in the center positions. If the next step up on the mains is too rich, you can set the needles down to lean it out in the mid range.
BTW, you have to sync the carbs every time you adjust the needles.
Last edit: 27 Jul 2017 21:27 by SWest.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
28 Jul 2017 04:57
#767863
What carbs are these?
'85 GPz550(ZX550-A2)
  • KZB2 650
  • KZB2 650's Avatar
28 Jul 2017 07:01
#767868
Check out Jets R us...... they show a 6F4 so I'm "guessing" this is the next step richer but would he start off on the 3rd slot?
1978 KZ650 b-2
  • SWest
  • SWest's Avatar
  • 10 22 2014
The following user(s) said Thank You: Buxvan
  • kyan44
28 Jul 2017 11:50
#767881
I have a pair of Mikuni VM30. When I open the throttle between 1/4 to 3/4 and I check the spark plugs, It is very lean. I have the clip on the 5th grove, it should make the needle rich. BUt I see no effect
