Keihin cv32 v54b vs v60a
- Mholtkz400ltd
22 Jul 2017 09:32 #767488
by Mholtkz400ltd
Keihin cv32 v54b vs v60a was created by Mholtkz400ltd
Hello all.
I'm in the process of rebuildin my carbs (well replacing one body with another) and I ordered a v54b carb body from a kz400b1/b2? Was curious what the difference was between my cv32 v60a? Jetting? I measured the bore sizes and they all match up. Am I OK to go on or do I return and just try an fix my carb? ( bent butterfly) don't want to mess my my stocks anymore than I have to because I have horribe luck lately and don't want to bend it more or not enough and screw myself over anymore than I might be.
Thanks for the help all.
MATT
MATT
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
23 Jul 2017 06:40 - 23 Jul 2017 06:48 #767523
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic Keihin cv32 v54b vs v60a
No eBay APP ID and/or Cert ID defined in Kunena configurationI'd recommend checking
www.kawasaki.com
in the "parts" section, and see if there are any interchangeable internal parts. This means they would have the same part number. Check to see the bikes both carbs came on, and if they use the same throttle cable part numbers. If not, there is always Ebay for another set of carbs.
Last edit: 23 Jul 2017 06:48 by CoreyClough.
- Mholtkz400ltd
27 Jul 2017 03:51 #767796
by Mholtkz400ltd
Replied by Mholtkz400ltd on topic Keihin cv32 v54b vs v60a
Sorry for the late reply my email was putting the kz400 notifications in my spam folder. I wound up returning the v54b body and just bending back my butterfly that was bent
