- Thank you received: 5
BS34 Carb Holders KZ750 Twin
- ric812
18 Jul 2017 17:33 #767279
by ric812
1982 Kawasaki KZ750M Twin CSR
BS34 Carb Holders KZ750 Twin was created by ric812
I am trying to find carb holders for a 1982 KZ750 twin with BS34 carbs. Z1 does not carry them and I can not find any. I have read that the XS400 holders or maybe the XS650 holders may work but I am not 100% sure. i have looked at
jbm industries
and the holders they carry have the right bolt to bolt measurement but the throat measurement is 2 mm to wide.
- azman857
- Thank you received: 112
19 Jul 2017 22:52 #767356
by azman857
Replied by azman857 on topic BS34 Carb Holders KZ750 Twin
Even the '80 and later one's? XS 650's used the BS 34's from '80 on.
- ric812
20 Jul 2017 03:29 #767363
by ric812
Replied by ric812 on topic BS34 Carb Holders KZ750 Twin
I contacted Z1 enterprises and they were nice enough to measure carb holder dimensions.
The XS400 Carb Holder 80' and up:
The center to center bolt hole measurement is 66mm
The ID on the carb side is 39mm
The ID on motor side is 33mm.
The XS650 Carb Holder 80' and up:
The center to center bolt hole measurement is 70mm
The ID on the carb side is 45mm
The ID on motor side is 34mm.
- ric812
30 Jul 2017 07:43 #767967
by ric812
I received the XS400 Carb Holder 80' and up and after over sizing the bolt holes by about 2 mm per hole , they fit perfectly with the BS34 carbs
