Vm24ss vents in inlet and air filter boots
- Ekacpuc
16 Jul 2017 23:55 #767140
by Ekacpuc
Vm24ss vents in inlet and air filter boots was created by Ekacpuc
There are two holes on the inlet side of the carbs. Does the stock boot block them or are they left open? Inside the throat.. when I clean them one led down to the main jet and I didn't check where other went.
- Thank you received: 2829
17 Jul 2017 05:33 #767153
by 650ed
Replied by 650ed on topic Vm24ss vents in inlet and air filter boots
The stock airbox ducts wrap around the outside of the carbs and do not block any orifices. Ed
The following user(s) said Thank You: Ekacpuc
