Pilot jet location - help
  • ric812
  • ric812's Avatar Topic Author
12 Jul 2017 11:43
#766778
I keep reading that the pilot jet is covered by a plug but the FSM does not really show where it is. This is on a BS34 carb from a 1982 kz750 twin car. I have attached pictures of the carb. Please help, I do not want to drill out the wrong spot.
1982 Kawasaki KZ750M Twin CSR
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: Pilot jet location - help
12 Jul 2017 12:13 - 12 Jul 2017 12:19
#766779
Are you sure those a BS34 carbs. I could be wrong, but they look a lot like the larger BS38 carbs that were stock on the earlier versions of the 750 twin. If that is the case then both the pilot jet and the main jet are screwed into the bowl and not the the carb body.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Last edit: 12 Jul 2017 12:19 by gd4now.
  • ric812
12 Jul 2017 12:45
#766781
No I am not sure. Is there anyway figure it out? Maybe measuring the more size? There is the main jet in the middle of the float bowl and another jet just to the side of it. I will have to post pictures of the float bowl once I get home.
  • mopguy
  • mopguy's Avatar
12 Jul 2017 13:25 - 12 Jul 2017 13:29
#766782
That's the one. If you have BS34, the pilot is fed through a passage in the main jet shaft.
Last edit: 12 Jul 2017 13:29 by mopguy.
  • martin_csr
  • martin_csr's Avatar
12 Jul 2017 14:27 - 12 Jul 2017 14:33
#766785
By ric812: No I am not sure. Is there anyway figure it out? Maybe measuring the more size?
You can measure the carburetor bore, but from the diagrams at Partzilla the BS38 bowl gaskets on the earlier 750-Twins are fairly distinctive. The BS34 bowl gasket appears to be a rubber o-ring type of gasket. There are other differences, but the bowl gasket is probably the most obvious.
Last edit: 12 Jul 2017 14:33 by martin_csr.
  • ric812
12 Jul 2017 15:43 - 12 Jul 2017 15:45
#766792
Here is some pictures of the float bowl
Last edit: 12 Jul 2017 15:45 by ric812. Reason: Wrong pictures
  • ric812
12 Jul 2017 15:47
#766793
Here is a pictures of the jet that was underneath the drain plug. There is a 13/16 deep well socket for size reference.
  • ric812
12 Jul 2017 15:59
#766794
Correct me if I am wrong but if I am measuring this right then this is a set of bs38 carbs.
  • ric812
12 Jul 2017 16:22
#766797
Since it looks like the carbs are not BS34 I ordered the wrong carb holder. Does Z1 have these holders?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
12 Jul 2017 16:49
#766801
Some BS38 specs
I hope it helps your carb journey
Michael
The following user(s) said Thank You: GPz550D1, ric812
  • ric812
12 Jul 2017 16:53
#766803
Thank you Scirocco. Thank will be alot of help.
