new exhaust for a 81 kz440
- anthonytanno
11 Jul 2017 15:42 #766708
by anthonytanno
new exhaust for a 81 kz440 was created by anthonytanno
will the exhaust off of a 1980 kz440 fit a 1981 kz440 as well?
- Nebr_Rex
- Thank you received: 300
11 Jul 2017 18:28 #766725
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic new exhaust for a 81 kz440
If it is the same model.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Thank you received: 1656
12 Jul 2017 05:42 - 12 Jul 2017 06:04 #766748
by martin_csr
Replied by martin_csr on topic new exhaust for a 81 kz440
If they are both Ltds, then it will probably work. According to the cross-reference at Partzilla all of the 440 Ltd models had a 2-2 muffler system & they share most parts. The diagrams at Kawasaki.com indicate that the 80-81 LH & RH mufflers are the same. The 82-83 have different LH & RH muffler part numbers, but they might be interchangeable with the earlier Ltds. guessing.
The 440B standard had a 2-1 exhaust. you might still be able to use a 440B, but you'd probably have to fab a muffler bracket.
Last edit: 12 Jul 2017 06:04 by martin_csr.
