- Thank you received: 38
SeaFoam in a tank that's been coated inside
- ezrider714
17 Jun 2017 20:56 #764637
by ezrider714
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
SeaFoam in a tank that's been coated inside was created by ezrider714
Yes or No ???
Coating unknown, was in tank when son purchased, There are area where the coating is missing and you can see the tank steel
However in 4 years have never found any residue in either the petcock screen or the fuel filter I put on it when I first saw the tank.
So I believe it's adhering well, but the bare spots are of some concern
Any experiences with coating being dissolved by the SeaFoam?? Or is it nothing to worry about
Any advice appreciated
EZ
EZ
Dyna Coils
- dkoz
- Thank you received: 17
18 Jun 2017 09:24 #764687
by dkoz
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
Replied by dkoz on topic SeaFoam in a tank that's been coated inside
I've used seafoam quite a bit and do not think it is ever affected any Linings in my tank. That being said I am against tank liners if you can get rust particles and old coating off inside of tank simply keep that tank full at all times. I had had a failing cream coat but it did not look like it from looking down into the tank it was the top of the tank where you could not see it was hanging down like the liner of an old car rust particles we're constantly clogged in my carbs that took a while to figure out. I did not believe seafoam caused the liner to fail I believe that to be with preparation
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
- Thank you received: 2829
18 Jun 2017 12:21 #764696
by 650ed
Agree! Ed
Replied by 650ed on topic SeaFoam in a tank that's been coated inside
dkoz wrote: .................. I am against tank liners if you can get rust particles and old coating off inside of tank simply keep that tank full at all times.........
Agree! Ed
- Coast Steve
- Thank you received: 22
18 Jun 2017 15:27 #764709
by Coast Steve
1982 Kawasaki Eddie Lawson S1 (1136cc race replica clone.)
Replied by Coast Steve on topic SeaFoam in a tank that's been coated inside
I agree also, Sea foam is 100% pure petroloum and I don't think it would affect a lined tank.
Last year I spoke on the phone with the techs at Seafoam and they will answer any questions you have.
The following user(s) said Thank You: ezrider714
18 Jun 2017 15:46 - 18 Jun 2017 15:47 #764710
by 650ed
? Seafoam is 40% - 60% Pale Oil; 25% - 35% Naphtha; 10% - 20% IPA (that's Isopropyl alcohol not India Pale Ale). Ed
youdiyauto.blogspot.com/2012/09/what-is-...eafoam-products.html
Coast Steve wrote: ...... Sea foam is 100% pure petroloum.......
Last edit: 18 Jun 2017 15:47 by 650ed.
- Coast Steve
18 Jun 2017 16:21 #764712
by Coast Steve
Sure ok, I called them and the tech said it's 100% pure petrolium. ...whatever that means.
- ezrider714
18 Jun 2017 18:26 - 18 Jun 2017 18:26 #764726
by ezrider714
Dyna Coils
Replied by ezrider714 on topic SeaFoam in a tank that's been coated inside
Naphtha would give me cause to ponder
I'm not fond of coatings inside a tank, but it was in there when my son bought the bike, I don't think it wise to try and remove it. Especially not knowing the condition of the tank that led a previous owner to do it.
may just call Seafoam
Thanks for the input
EZ
EZ
Dyna Coils
Last edit: 18 Jun 2017 18:26 by ezrider714.
