Very High "Idle"
- 78KZT
14 Jun 2017 18:44 #764396
by 78KZT
Very High "Idle" was created by 78KZT
I have a 1978 KZ1000A2. The bike sat for around nine years, now I have gotten it running again. The bike starts great, accelerates and runs good - except: I can't get the idle down below 3K RPM. I do have a 4 into 1 exhaust (which it ran good with before) I installed pod filters (MOXI) and put larger pilot and main jets in the carbs. I also replaced the intake manifolds (carb holders).
Adjusting the pilot screws has no effect on idle speed. The throttle pulley isn't touching the throttle stop. The throttle seems to be smooth in operation.
Suggestions?
Suggestions?
- Thank you received: 2755
14 Jun 2017 18:55 #764398
by SWest
Replied by SWest on topic Very High "Idle"
Have you bench synced the carbs?
- Thank you received: 2098
14 Jun 2017 19:00 #764401
by Patton
Replied by Patton on topic Very High "Idle"
Imperfect pilot circuits?
Bench sync with insufficient throttle knob thread remaining?
Hanging advancer?
Hanging advancer?
The following user(s) said Thank You: GPz550D1, 78KZT
