- Thank you received: 3
Smoothbore jetting.
- TerryK
13 Jun 2017 18:02 #764319
by TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Smoothbore jetting. was created by TerryK
Finally ditched the 29 flatslides and I'm Looking for baseline jetting for 33 smoothbores. KZ1075, hot street cams, mild porting, dyna, Wiesco header.
Thanks fellas!
Thanks fellas!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- Thank you received: 2755
13 Jun 2017 18:08 #764320
by SWest
Replied by SWest on topic Smoothbore jetting.
Depends on the slide cutaway. If 1.5 this is a starting point. I have 2.0 so my pilots are much larger.
jetsrus.com/carburetor/carb_mikuni_VM33_...oded_view_parts.html
- TerryK
13 Jun 2017 19:27 #764327
by TerryK
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Replied by TerryK on topic Smoothbore jetting.
The guy who owned them before couldnt get the bike to run right and now I know why. He had 107.5 mains and a #60 pilot lol.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
13 Jun 2017 19:56 #764330
by SWest
I'm running 125, 65 with the 2.0 slides. I'm going the other way.
