82 Spectre Shaft Drive N1 Carb Vacuum routing?
  • jenningsjesse
  • jenningsjesse's Avatar Topic Author
11 Jun 2017 09:08
#764083
I have a 1982 Spectre 750 Shaft Drive N1 with Keihin CV34-4 carbs us model. I just bought the bike and doing carb cleaning service and sync. There is the vacuum plug on carb #2, and 3 vacuum hoses to other carbs. I thought the plug was supposed to be on carb #3? Thr hose is long enough from petcock to go #3, but still thinking it should go to #2, and plug should be on #3. Please help
  • TexasKZ
  • TexasKZ's Avatar
Re: 82 Spectre Shaft Drive N1 Carb Vacuum routing?
11 Jun 2017 11:24
#764091
Typically, the vacuum ports on 1 & 4 are capped, 2 is connected to the fuel valve (petcock) and 3 is connected to the Clean Air System, but in reality it doesn't matter as long as the ports not being used are capped.
  • martin_csr
  • martin_csr's Avatar
11 Jun 2017 13:20
#764099
At Partzilla the carburetor assy diagram seems to show that #2 has the plug & #3 the petcock vacuum line, but it doesn't matter.
The clean air system vac lines would be connected to the #1 & #2 vac ports.
The following user(s) said Thank You: TexasKZ
