Pulley stop screw
  • Fox
  • Fox's Avatar Topic Author
Pulley stop screw
06 Jun 2017 09:16
#763720
Hello,
can someone tell me
- what is for the pulley stop screw ?
- Do you use the pilot screw limiter to work,or do you srew the pilot screw and then unscrew 1.5 turn.
Best
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Conspiracy
  • Conspiracy's Avatar
Re: Pulley stop screw
06 Jun 2017 13:31
#763729
I'll try to answer about the pulley stop screw -
The pulley stop screw is an adjustable screw that allows the throttle pulley to stop all the way closed or slightly open. It should work in conjunction with the carb sync and idle screw because all of it working together will determine your idle speed.
Novice rider
1976 KZ900
The following user(s) said Thank You: Fox
  • Fox
07 Jun 2017 01:34 - 07 Jun 2017 02:25
#763789
Ok thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
Last edit: 07 Jun 2017 02:25 by Fox.
