1979 Kz650 c3 carb jetting
  • Spike2902
  • Spike2902's Avatar Topic Author
29 May 2017 11:57
#763031
Hey guys just curious if you can help me I'm trying to get my carbs all sorted out I have a 1979 kz 650 c3 and it has pod filters along with the 4 into 2 Exhaust but I straight piped the exhaust by cutting out all the chambers inside the pipes I went one up to a 100 on the main jet and it runs well but from idle to 1/4 throttle it bogs out if you pin it all the way if you slowly rev it is fine I have the jet needle in the middle position with the clip and the air screws are all 3/4 turned out I went up one pilot jet to a 17.5 and it wouldn't start at all even with starting spray so I'm not sure where to go from there also I have bench synced the carbs
