- Benedetto
28 May 2017 08:31
alrighty-first time posting here-be gentle. i claimed this '84 KZ as abandoned property last year and was excited to finally get all of her papers and now she is legally mine. However after some minor maintenance (spark plugs, oil filter and new battery) i finally got her running. Although the idle needs to be adjusted, I took it her for a belt around town. There was some intermediate power surges which I contributed to dirty carbs and possibly old fuel. The bigger problem is, she pukes oily fuel after I shut her off. After some research I took the carbs off-cleaned them, replaced the petcock and fuel filter. Its still pukes oily gas after shut off!!! I'm pretty sure its got to do with the vacuum-is it possible the petcock didnt seal? The gas cap also seems a little loosey goosey; could it be causing vaccum after the bikes shut down? will post pic soon
- Nebr_Rex
Re: #$@$%%
28 May 2017 09:05
Are you using a manual?
Perform all regular maintenance on the engine like valve lash, ignition and clean the carbs.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- davido
Re: #$@$%%
28 May 2017 09:18
Ive just rebuilt my fuel tap,using this;
xjbikes.com/forums/threads/rebuilding-th...-valve-w-pics.25058/
Seems to have cured my incontinence.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- Benedetto
- bluej58
Re: #$@$%%
28 May 2017 10:11 - 28 May 2017 10:20
pukes out of what, the carbs or exhaust?
84 kz what?
Does that year have points?
Get some DeOxit- 5 and clean "all" of your connections.
You will get more responses if use a subject title that has something to do with the problem instead of swearing at us.
Welcome
84 kz what?
Welcome
78 KZ1000 A2A
Last edit: 28 May 2017 10:20 by bluej58.
Re: #$@$%%
28 May 2017 15:43
If you did not carefully polish the internal parts of the petcock, it may still leak. If the new rubber bits were not genuine Kawasaki, they may leak. If the float valves in each carburetor are not properly sealing, or of the fuel level in the carbs is set way too high, you will have overflow. The only way I can imagine oil being in the fuel is if there is oil in the fuel tank, or the fuel is running out of oiled filters, like K&N, and washing the oil away. If the fuel is filling up the crankcase and overflowing a fuel/oil mixture, you have a dangerous situation that needs to be corrected before you start the engine again.
Re: #$@$%%
29 May 2017 06:38
Agree with the comment questioning where the "oily fuel" is puking from.
If the petcock is leaking it's highly likely that you have gasoline inside the crankcase. Check the oil level and if it's over the full mark an oil change is in order straight away.
