Runaway Throttle?
- brakedust
16 May 2017 11:44 #762035
by brakedust
Runaway Throttle? was created by brakedust
1983 GPZ550
Start the bike up.
Idles around correct RPM for a second or two.
Then It begins to climb moderately slow - till around 7k.
- Sticky Throttle cable?
- Air Leak - but then it needs fuel too?
- Potential Wrong slide in carb?
- Leaning out?
Thoughts?
Trying to make a checklist, before I tackle this.
New to the KzRider Forum. Any insight appreciated!
Start the bike up.
- Leaning out?
Thoughts?
- JOE MKII
- Thank you received: 25
17 May 2017 03:57 #762060
by JOE MKII
I believe its called "Oppositional Defiance Disorder"
Replied by JOE MKII on topic Runaway Throttle?
All of the above, most likely an air leak, wrong slide is unlikely but one never knows, if its a slide its more likely a torn or perforated seal on the top of the slide ( i belive those are cv carbs??)
I have never been able to solve that problem on any bike without a through going over and carb rebuild. Lots of places for air to get into the carb. Look at the parts fiche for the intake system and the carb... multiply points for bad seals and air leakage.
Check sticky throttle and air leaks first.
Good luck!
Good luck!
