Where did these carbs. came from ?
- kzdcw
- 77' KZ1000A
10 May 2017 11:18
I got these used 28mm pumpers I purchased recently really well cleaned. The seller said they were from a 79' KZ1000 ? Main jet size is #110 and Pilot jet size is #15. Jets are original to the carbs. Can't seem to find out anywhere where these carb. were mounted on what model of KZ ? Anybody have any ideas ?
77' KZ1000A
The following user(s) said Thank You: Dangerous
- peter1958
- Banned
Re: Where did these carbs. came from ?
10 May 2017 12:15
79-80 mark 11
www.kzzone.com/
- MDZ1rider
10 May 2017 12:35
80 Z1R (D3) came with 28mm pumpers as well.
- peter1958
- Banned
10 May 2017 12:44 - 10 May 2017 12:44
I thought the z1r had 28 mm but no pumper.
www.kzzone.com/
Last edit: 10 May 2017 12:44 by peter1958.
- DOHC
- Those Doe-Hawks really go!
26 May 2017 21:17peter1958 wrote: I thought the z1r had 28 mm but no pumper.
The '78 Z1R had 28mm without pumps. The '80 Z1R had 28mm with pumps.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- rrsmsw9999
27 May 2017 05:17
The 79=80 shaft KZ1000 had them too. People like em, but they are PIA to clean up. The check valves, balls and spring clamps are hard to replace and deal with. Could always salvage bowls and ditch the pumper. Rejet required. The pump is to accommodate lean idle emissions. It just dumps fuel on initial accel. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- Nebr_Rex
27 May 2017 06:29kzdcw wrote: I got these used 28mm pumpers I purchased recently really well cleaned. The seller said they were from a 79' KZ1000 ? Main jet size is #110 and Pilot jet size is #15. Jets are original to the carbs. Can't seem to find out anywhere where these carb. were mounted on what model of KZ ? Anybody have any ideas ?
"79 KZ1000st
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- dkoz
28 May 2017 12:34
80 ltd as well
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
