Need advice re 1983 Kawasaki KZ550 that idles high
  • NDSpectre
  • NDSpectre's Avatar Topic Author
19 Apr 2017 09:10
#759592
Have a 1983 Kawasaki Spectre KZ550 that has only 1400 original miles. Carbs were rebuilt by wiredgeorge a few years ago down in TX. Bike has been in storage for last few years (winterized properly). Put in a new Yuasa battery, new petcock, fuel, and fired up the bike a few days ago. The idle is hovering around 4000 - 5000 rpms at startup. I can open the choke to just about halfway (were the detent is in the choke closure) and it will reduce to about 3000 rpms. If I open the choke any more, even when at operating temperature, the bike will cough and die. Starts right back up again, but after closing down choke a bit. Bike rides fine and has never perfect compression in all 4 cylinders (given the extremely low mileage for a 34 year old bike). I have not synced the carbs as I do not have a Motorcycle Vacuum Carburetor Synchronizer. Further, the idle set screw seems to have no effect on the idle. Last, throttle cable grip play is adjusted properly to 2-3mm. Any suggestions?
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Need advice re 1983 Kawasaki KZ550 that idles high
19 Apr 2017 09:42
#759597
They all do that, the earlier slide carb 550's too.
Just avoid leaving on full choke when cold and move off as soon as started on half choke. Knock off the choke as soon as you can. The 550's are all grumpy when cold, after a mile it will wake up. Thrashing a cold engine is best avoided.
  • NDSpectre
19 Apr 2017 13:33
#759618
Can anyone give me advice on how to set the idle set screw - hot/cold, as it seems to have no effect once the bike is started and warmed up on the idle speed. Also, does turning it clockwise supposed to increase or decrease idle speed?
  • Nessism
  • Nessism's Avatar
19 Apr 2017 15:32
#759626
Backing out the screw reduces the idle.
The following user(s) said Thank You: GPz550D1, NDSpectre
  • rrsmsw9999
  • rrsmsw9999's Avatar
20 Apr 2017 08:21
#759664
Not sure of you model but KZ550 carbs have a high idle set screw. Loudvx has a page that details how you can put an adjustment knob on it instead of needing to wrench. Seasonally the idle RPM blasts high on full choke. It's an ambient temperature issue. Proper high idle in summer will die in the winter. Proper high idle set in colder temps will cause it to scream up to 6k rpm in summer. The knob is a great way to adjust high idle to ambient temp changes. Also like others have said, most 550s are cold blooded and will need to operate the first few minutes with choke on or they will spit sputter and die. Once warmed up this is not an issue. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
The following user(s) said Thank You: NDSpectre
  • Tyrell Corp
20 Apr 2017 09:10
#759668
The Lou mod is for the older slide carbs IIRC,
Modifying the enrichment circuit 'aka choke' on CV carbs for seasonal variations might be more involved.
I've had a few kawi 550's - they all do it.
