Mikuni BS34 Has Me STUMPED!
- KZ1000P1995
Re: Mikuni BS34 Has Me STUMPED!
25 Oct 2017 10:39
Final update: I believe the entire problem was due to adjustment of the pilot jets. Everywhere I read it was 2 -2.5 turns out. Well, when I played with it a bit more I discovered that AT SEA LEVEL, it worked best at about 3.5 turns out for my bike. Once I adjusted the pilot jets it helped tremendously. It's still "cold blooded" and needs some tuning to really idle right, but at least I know it's NOT dirty carbs, bad valves, or ignition. It turned out to be a simple adjustment that kept me from riding for the last 2 years (tears anyone?). Anyway, I hope that my fiasco helps someone else with their bike. Cheers!
25 Oct 2017 13:43
Pilot jets are not adjustable. Hopefully you are talking about the pilot screws located on the top front of the carb body.
- GPZ1100_Rider
25 Oct 2017 14:33 - 25 Oct 2017 14:35
After reading this post front to back, I was surprised that no one mentioned ultrasonic cleaning for carb cleaning. Seems like its the cat's meow anymore, for getting the carbs' passage ways cleaned out thoroughly and with confidence.
A check of the fuel levels in the float bowls, and a carb sync wouldn't be a bad idea.
Last edit: 25 Oct 2017 14:35 by GPZ1100_Rider.
