- Thank you received: 55
K&L Mikuni parts any good?
- Z1Driver
- love the smell of triple smoke
18 Apr 2017 10:38 #759507
by Z1Driver
Blue 1975 Z1B
Red 2009 Concours 14
K&L Mikuni parts any good? was created by Z1Driver
I am looking at a set of Mikuni VM28's which were rebuilt using K&L parts. I would be more enthused had Mikuni parts been used. The question is are the K&L parts quality good enough for the 28"s or would I be fighting them trying to get them to run? Thanks in advance. Tim
Blue 1975 Z1B
- Thank you received: 2839
18 Apr 2017 11:16 - 18 Apr 2017 11:17 #759510
by Nessism
Replied by Nessism on topic K&L Mikuni parts any good?
K&L carb parts are not the worst, but they are NOT up to OEM Mikuni level either.
In particular, the K&L float needle springs are weaker than the stock Mikuni springs and often times the weight of the float will cause the needles to deflect which can lead to an increased fuel level in the bowls. You best measure fuel height using the clear tube method if you pull the trigger on those carbs. Also, check the jet numbers and compare to stock. Sometimes the rebuild kit jets are generic and span many years, however Kawasaki changed the jetting on an almost year by year basis.
Last edit: 18 Apr 2017 11:17 by Nessism.
- Z1Driver
18 Apr 2017 22:35 #759566
by Z1Driver
Blue 1975 Z1B
Replied by Z1Driver on topic K&L Mikuni parts any good?
Thanks for the reply. I will take it into consideration for sure.
Blue 1975 Z1B
