28mm Pumpers ?
- kzdcw
- 77' KZ1000A
28mm Pumpers ?
13 Apr 2017 07:54
I'm looking at some Mikuni 28mm accelerator pump carbs. and looking at the photos, it doesn't have the 3-screw Vacuum Sensor Cover mounted. Apparently it is missing ? Is it needed for the carbs. to operate ?
77' KZ1000A
- rrsmsw9999
Re: 28mm Pumpers ?
13 Apr 2017 08:41
On those 28mm pumper carbs all are cast for the sensor but not operational. The 1980 ST I had was a bare open receptacle for the sensor but not completely milled or operational. No leaks there and no need to cover. I believe the FSM is where i found this detail. BTW, the pumper carbs are a useless PIA. it only dumps gas to avoid a lean idle circuit. the little check valves, clips and ball bearings are a PIA too. Find some regular bowls or non pumper carbs ard re jet IMHO.
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- zed1015
Re: 28mm Pumpers ?
13 Apr 2017 10:14
Nothing is missing on those 28's.
The pumper float bowl is a common casting to both the 26mm and 28mm carbs however both diaphragms were only used on the 26mm ones .
On the 28's this diaphragm is not used so the casting in that area remains un machined and no cap fitted.
- kzdcw
- 77' KZ1000A
Re: 28mm Pumpers ?
13 Apr 2017 12:35
Now that I have that ruled out about the casting cap, I'm wondering if I'm just wasting time focusing on the pumpers whether something better for my engine build with a 1075 kit and possibly head and cam work ?
29 Smoothbore's are unaffordable but BS34's are ? Just not sure about a CV carb. as oppose to a slide type ?
77' KZ1000A
- zed1015
Re: 28mm Pumpers ?
13 Apr 2017 13:38
Those 28 pumpers are the best of all the zed slide carbs.
If they are good condition at the right price I would snap them up.
It's the 26mm pumpers that are shite not the 28's.
Don't bother with CV's and 29 smoothies won't have any advantage and can be much harder to set up.
Re: 28mm Pumpers ?
13 Apr 2017 13:47
Agree but I'd like to see what we're talking about.
