1976 KZ400 jetting w/ pod filters
- loudhvx
Re: 1976 KZ400 jetting w/ pod filters
23 Apr 2017 08:25Patton wrote: If anyone ever gets a KZ400/440 with pods to perform on par with the stock setup, please call Guinness. :lol:
We got it ride-able in a few days of tinkering with jets, but then would occasionally make tweaks. It took almost 3 years to arrive at the final jetting/exhaust setup. We probably rejetted half a dozen times over that period. So yes, it's no simple task when starting from scratch.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Patton
- Nebr_Rex
23 Apr 2017 08:43I was replying to Patton.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- alinaaseh
23 Apr 2017 09:55
loudhvx,
The pistons do indeed rise and fall in unison, and slide freely in the carb body. I will check the air jets today - wouldn't be surprised if they're in one another's spots. Hopefully that will do the trick, seeing as my jetting is relatively similar to what your setup was a decade ago (albeit, all my parts are for the KZ and I haven't drilled my pilot to the size of the moon).
Patton,
I'm with you on this one... if I can't get them to run correctly in the next few tries, I'm ready to pick up a couple of mikunis and call it good!
Patton,
1976 KZ400 D3
Ft. Collins, CO
Ft. Collins, CO
23 Apr 2017 10:27
Have you considered simply installing the stock air box and filter? That way you may be able to ride before the summer ends.
- alinaaseh
23 Apr 2017 10:31
The same thing popped into my head about two weeks ago... That's the reasonable route... But instead, I picked up a 1980 Yamaha xs850 to ride while I continue to tinker with the Kwak...
1976 KZ400 D3
Ft. Collins, CO
Ft. Collins, CO
- Nerdy
23 Apr 2017 12:32alinaaseh wrote: I'm with you on this one... if I can't get them to run correctly in the next few tries, I'm ready to pick up a couple of mikunis and call it good!
If you're interested, I'm going to be selling a set of Mikuni VM30s (and dual throttle cable) from DCC. The plan was to swap the carbs on my '79 KZ400 this summer but now I'm passing the bike to my brother so the nephews can ride it.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- alinaaseh
23 Apr 2017 14:18
Hi all.
I've come to admit that I made a very rookie mistake and have wasted your time. After ensuring that the air jets were in the correct spot (they were), I realized something that I should've realized long ago.
The carbs have an idle adjustment screw that changes the position of the butterfly valves, and it was locked up until today. I admit - I never once thought to tinker with it, as I believed it was part of the assembly that held the carbs together. A blast of wd-40 and a quick soak freed it right up.
I'm embarrassed that I spent so much time fiddling with jets when the solution was right there all along. I am, however, excited that the bike rides, and looking forward to tuning the carbs to their fullest extent.
Thanks for tolerating my idiocity. Much appreciated.
1976 KZ400 D3
Ft. Collins, CO
Ft. Collins, CO
- alinaaseh
23 Apr 2017 14:54 - 23 Apr 2017 14:55
Two more things, both of which are purely for other users' information:
1) Jetting at this point (will update as I make tweaks):
- #40 pilot
- #40 slow
- #140 main
- #60 main air
- #90 pilot air
2) Took the bike for a spin around the neighborhood, made it quite a ways before it began to splutter, gurgle, and eventually die. I suspect an electrical problem. Voltimeter reads ~13v when running and drops by ~1/10th of a volt every few seconds. Revving the engine does not produce any sort of spike or increase in charge, which leads me to suspect a stator issue. Will post in electrical subforum if I can't figure it out on my own.
Many thanks.
- #40 pilot
- #40 slow
- #140 main
- #60 main air
- #90 pilot air
Many thanks.
1976 KZ400 D3
Ft. Collins, CO
Ft. Collins, CO
Last edit: 23 Apr 2017 14:55 by alinaaseh.
23 Apr 2017 15:05
I wouldn't jump to a conclusion that there is a stator problem. Instead, run the charging system tests in the Kawasaki Service Manual to diagnose and pinpoint the source of the problem. Keep in mind the problem could very well (and more likely) be in the rectifier or in the regulator or even in the wiring or a bad connector. My KZ650-C1 had a charging problem, and the tests in the manual very quickly identified it as a bad diode in the rectifier. I replaced the rectifier and presto / chango no more problem. Ed
- Nebr_Rex
23 Apr 2017 16:03alinaaseh wrote: Hi all.
Damn Ed!
He didn't even make it to summer.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
23 Apr 2017 16:57 - 23 Apr 2017 16:59
:laugh: :laugh: :laugh:
I'm glad he found the issue so he wasn't reduced to riding a Yamaha all summer. Ed
Last edit: 23 Apr 2017 16:59 by 650ed.
- loudhvx
I was just interested in seeing your project and was bummed the link didn't work.
1981 KZ550 D1 gpz.
Other links.
Other links.
