VM 29 A12 smoothbores
  • Buster
  • Buster's Avatar Topic Author
09 Apr 2017 19:27
#758881
I have a set on my 1075 with 4-1 and pods. These have the 2.0 cut away slide. Main is 120 , pilot is 20. Will only idle with air screw full in. Anyone running the 2.0 slides? What size pilot are you running? Definitely getting too much air as is. If I go way up on the pilot will I need to drop the needle and go a little smaller on the main?
IF A TURTLE DOESN'T HAVE A SHELL, IS HE HOMELESS OR NAKED?
  • spdygon
  • spdygon's Avatar
Re: VM 29 A12 smoothbores
12 Apr 2017 20:10
#759067
On my Z1r I got 25 pilots 125 mains
4-1 KerKer
Velocity stacks
My 76kz900 22.5 pilots 120mains
4-1 kerker
Air box
Bothe only 1/4 turn out on air screw
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
The following user(s) said Thank You: Buster
  • jdvorchak
  • jdvorchak's Avatar
14 Apr 2017 05:48
#759154
Just my 2 cents. Up the pilot to 22.5 and forget about the needle and mains. If it runs fine now off idle to red line, your mains and needle are fine. Those are two different circuits and very little overlap. Actually with larger pilot you may find the transition from idle to mid range throttle smoother and more responsive throttle.
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
18 Apr 2017 13:38
#759527
The air screws on the vm29s are different than on the other (smaller) Mikuni carbs. There is a hole near the end of screw that the other carbs air screw do not have. Due to this hole the screw needs to be set differently than the other type of screws.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Buster
10 May 2017 19:46
#761677
So I went with 25 pilots and 120 mains. Huge difference! Idles great and runs strong from idle to WFO. Thanks all!
spdygon wrote: On my Z1r I got 25 pilots 125 mains
4-1 KerKer
Velocity stacks
4-1 kerker
Air box
  • KZB2 650
  • KZB2 650's Avatar
11 May 2017 06:40
#761710
Where did you end up with the air screw.... I'll try probably try 20s and 1/4 turn out on my little 700 when I get to em.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • Buster
11 May 2017 06:52
#761713
I'm about 1/2 a turn out on all of them. Do you have the 2.0 slides in your 29mm smoothbores?
  • KZB2 650
  • KZB2 650's Avatar
11 May 2017 06:56
#761714
Thanks .... will try cranking them in and nope mine are the 1.5s.
1978 KZ650 b-2
  • Buster
11 May 2017 07:05
#761717
OK, the 1.5 slide cut away doesn't flow as much air at idle. You might find you can need to open the air screws a bit more to get good idle and low speed perf. 120 mains, 20 pilots and 1.5 slides are the start point for a stock 900. You should be pretty close with a hopped up 700.
