No plug in primary jet cv34
- bsmithaert1
08 Apr 2017 11:06 - 08 Apr 2017 11:07 #758789
by bsmithaert1
No plug in primary jet cv34 was created by bsmithaert1
Picked up a 83 kz750 ltd shaft, haven't gotten it up and running yet, but while cleaning the carbs niticed that there are no plugs in the float bowl area for the primary jet. I stole a photo from another thread to illustrate what I'm talking about.
My carbs differ slightly, no overflow tube, and only the main jet and primary showing, but is there supposed to be a rubber plug on mine as well, or will the absence of the plug cause issues?
Last edit: 08 Apr 2017 11:07 by bsmithaert1.
- Thank you received: 1656
08 Apr 2017 13:05 - 08 Apr 2017 13:19 #758794
by martin_csr
Replied by martin_csr on topic No plug in primary jet cv34
I did not see the polyester cap w o-ring in the carb parts diagram for your bike. 83 750-F1.
Also, there only seems to be a main jet & pilot jet (no secondary main jet).
Last edit: 08 Apr 2017 13:19 by martin_csr.
- bsmithaert1
08 Apr 2017 14:59 #758795
by bsmithaert1
Replied by bsmithaert1 on topic No plug in primary jet cv34
I should've looked at the diagram, now I feel a little silly.
Thank you for the reply
