- Thank you received: 50
Carb removal 81 kz750LTD?
- jdvorchak
07 Apr 2017 19:23 - 07 Apr 2017 19:24 #758749
by jdvorchak
Don't fix it until it's broken.
John
83 KZ550M1
83 KZ1100LTD
Also own:
2010 Harley Ultra Classic Limited, 2008 Harley low rider 71 CB350/sidecar
Replied by jdvorchak on topic Carb removal 81 kz750LTD?
since the carbs go further into the intakes than into the air box boots, I always seat the carbs into the intakes first. Once they are in it's easier to get the air box boots on. Then I tighten the intake clamps, re position the air box and tighten those clamps. Once the boots are on and the carbs fully seated put the bolts back into the air box to hold everything in position.
Also helps that I use a liberal amount of petroleum jelly on the rubber intake parts to let the carbs slide in easier. Only put the jelly on the air box boots as a last resort. Usually have a problem getting them all on and in place without sliding back off before I get the clamps in place.
John
83 KZ550M1
83 KZ1100LTD
Also own:
Last edit: 07 Apr 2017 19:24 by jdvorchak.
The following user(s) said Thank You: mopguy
- rosko77
09 May 2019 19:46 #803620
by rosko77
Replied by rosko77 on topic Carb removal 81 kz750LTD?
the ltd has chrome fenders..thats about the only difference
- rosko77
09 May 2019 19:47 #803621
by rosko77
i found it was easier pushing em thru the airbox holes then by installing them push and wrk em thru the inside of the air box
- Oldjeep
10 May 2019 08:20 #803642
by Oldjeep
Yup, that is the easiest way I found too. I just disconnect them from the carb and push them half way into the air box - remove carbs from manifold and then install in reverse order. Trying to install those completely from the outside was near impossible
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
Replied by Oldjeep on topic Carb removal 81 kz750LTD?
rosko77 wrote: i found it was easier pushing em thru the airbox holes then by installing them push and wrk em thru the inside of the air box
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
The following user(s) said Thank You: rosko77
