How tight?
- dberg
How tight?
05 Apr 2017 17:40
I put new carburetor intake manifolds on my 1979 ltd 1000. Question is, what should they be torqued at.
Thanks!!
Thanks!!
- FrankenKZ650
Re: How tight?
05 Apr 2017 19:19
Put some medium strength thread locker on the bolts and make them snug. No need to go crazy tight.
1977 KZ650 (1982 KZ750-4 Engine)
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
The following user(s) said Thank You: dberg, GPz550D1
- daveo
Re: How tight?
06 Apr 2017 07:14dberg wrote: I put new carburetor intake manifolds on my 1979 ltd 1000. Question is, what should they be torqued at.
Thanks!!
New manifolds conform to the shape of the intake flange of the cylinder head over time. As that happens the bolts need to be checked and tightened to compensate for the compression of the rubber.
Mine needed tightening after about a week, and will get checked again as the rides become more-frequent.
1982 KZ1100-A2
- KZB2 650
Re: How tight?
06 Apr 2017 07:15
I use allens on mine so was able to set at 60 inch lbs... felt good and snug and not too tight.. second the blue loctite.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Re: How tight?
06 Apr 2017 17:18
Tighten until they strip, then back off 1/4 turn :pinch:
