Need help syncing carbs on GPZ 900
- 2005jetta
04 Apr 2017 15:47
We are attempting to sync the carburetors right now however I'm running into a problem. I understand that there is for vacuum lines that run to the sync gauge however the port on the number two carburetor is vacuum for the gas tank. Is that where I hook up the line for the number two carburetor? I was thinking that that would kill vacuum to the gas tank and fuel would not flow while syncing the carbs. I was able to hook up 3 to the gauges but they are jumping around erratically when making adjustments. There is only 3 adjustment screws while syncing, correct? They are the screws between each set of carbs? Any ideas? Thank you in advance.
Re: Need help syncing carbs on GPZ 900
04 Apr 2017 15:58
Yes, you must disconnect the vacuum line to the petcock to hook up the tool for synchronizing. If you are going to use the fuel tak instead of a remote tank, put the petcock on PRI.
If your guages are jumping around, they may need inline restrictors.
You have already adjusted the valves, haven't you?
- 2005jetta
04 Apr 2017 17:07
Thanks man! We just got him synced up perfectly.
