Carburetor/fuel tank/air box
Re: Carburetor/fuel tank/air box
30 Mar 2017 13:57 - 30 Mar 2017 13:58dkoz wrote: I would imagine you still have a float issue going on here. As stated if fuel is backing up into the box
Agree! Even if the petcock fails and lets fuel flow with the engine off the floats should stop the flow when the fuel reaches the prescribed level inside the carb bowls. Ed
Last edit: 30 Mar 2017 13:58 by 650ed.
30 Mar 2017 14:25650ed wrote:dkoz wrote: I would imagine you still have a float issue going on here. As stated if fuel is backing up into the box
Yup.
The following user(s) said Thank You: dkoz
- lucasr225
30 Mar 2017 14:40
Yah now that is all good and taken care of and figured out. She runs great and everything seems like it was before I cleaned the carbs. Where are the screws for which I plug my carb synching tool too?
1981 kz750 e2 standard 4
30 Mar 2017 15:16 - 30 Mar 2017 15:32
Rubber plugs not screws
First set carb ( #1 and #2 to equal value ), then ( #3 and #4 to equal value )
Then adjust the both pair ( #1/#2 ) and ( #3/ #4 ) to the same value.
Replay this procedure till all carbs are on the same value.
Michael
Michael
Last edit: 30 Mar 2017 15:32 by Scirocco.
The following user(s) said Thank You: GPz550D1, lucasr225
- lucasr225
30 Mar 2017 17:17
Thank you very much!!
- Kray-Z
- I need more power Scotty....
30 Mar 2017 21:25
Just a note about non - vacuum KZ petcocks - I have a customer's KZ that had the internal valve parts installed backwards or 180 deg. out when he brought the bike to me. It has been such a long time now that I forget exactly what was wrong with that (operationally) that made me take it apart, but I seem to recall that the petcock shut off flow completely on RES, and ON allowed the tank to run dry...something like that...
31 Mar 2017 05:59Kray-Z wrote: Just a note about non - vacuum KZ petcocks - I have a customer's KZ that had the internal valve parts installed backwards or 180 deg. out when he brought the bike to me. It has been such a long time now that I forget exactly what was wrong with that (operationally) that made me take it apart, but I seem to recall that the petcock shut off flow completely on RES, and ON allowed the tank to run dry...something like that...
Yes, and sometimes folks will modify a problematic vacuum petcock to make it function manually rather than rebuild it as stock. If yours has been modified intentionally or accidentally, it may not act as it should. In any case, the carbs should not overflow no matter what the petcock is doing.
