New float needles are sticking
  • KZB2 650
  • KZB2 650's Avatar
Re: New float needles are sticking
26 Mar 2017 10:19
#757738
Thats a huge difference in length ...... didn't the floats need adj big time to get the level right or did the seats do it..... new originals might be better here?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
26 Mar 2017 10:22
#757739
fatcat70 wrote: ... I tried cleaning the needles and seats a few times but it just wasn't helping.
What cleaning method was used?
Sometimes it's possible to use a q-tip in a cordless drill with some carb cleaner or Brasso to clean and polish the seats.
Could also closely examine the needle tips and perhaps polish the tips with a buffer.
The needle should freely drop of its own weight when not held inside the seat.
Good Fortune! :)
  • fatcat70
  • fatcat70's Avatar Topic Author
26 Mar 2017 11:28
#757743
I soaked the needles and seats in cleaner overnight and I used a q tip in a drill to clean out the seats.
1980 kz550 LTD
  • Nessism
  • Nessism's Avatar
26 Mar 2017 12:03
#757745
A piece of gray scotcbrite, preferably a piece that's a little worn out to knock down the grit level, cut into a strip and stuffed inside the float valve will help scrub it out. Stuff the piece inside and then press down while turning it around a few times to clean out any varnish or sludge that may be down inside.
The problem with aftermarket needles is the spring is weak so the seat pressure is low. It's customary to have to raise the float when using aftermarket float needles. You can get real deal Mikuni float seats w/needle for good prices off Amazon. It takes a little searching to be sure to match up the right size and number so take your time. Jets R Us has the dimensions so you can compre.
  • fatcat70
27 Mar 2017 07:06
#757810
Awesome thank you! I'll give that a try tonight!
1980 kz550 LTD
