- Thank you received: 7
Need choke/enrichener bushing
- Skiprrdog
- "Are we there yet?"
22 Mar 2017 15:48 #757412
by Skiprrdog
1983 KZ1100 A-3 Shaft
1976 KZ900
1975 H2 Triple
1984 Yamaha XJ900 Seca
1984 Harley Davidson FXRDG
#BlackBikesMatter
Need choke/enrichener bushing was created by Skiprrdog
I have a set of the 28mm carbs from an early 1970's Z1900 and I am missing the little plastic bush from one of the four enricheners. I am posting a picture (these are different carbs, but it is the same part) it is the little white plastic bit. Anyone know where I can get one?
Thanks!
Skip
Thanks!
Skip
1976 KZ900
1975 H2 Triple
#BlackBikesMatter
- missionkz
22 Mar 2017 22:18 #757443
by missionkz
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Replied by missionkz on topic Need choke/enrichener bushing
I've seen them numerous times on eBay.
Bruce
1977 KZ1000A1
- Thank you received: 2829
23 Mar 2017 05:06 - 23 Mar 2017 05:06 #757452
by 650ed
Replied by 650ed on topic Need choke/enrichener bushing
Check with Z1E to see if this is what you need. Ed
www.z1enterprises.com/choke-rod-collar-pull-nylon.html
Last edit: 23 Mar 2017 05:06 by 650ed.
