I want to fit Kn filters to a 1983 GPZ 750 A1
  • Bargoth
  • Bargoth's Avatar Topic Author
10 Mar 2017 16:24
#756366
Hi guys new here and need some help.
I want to remove the air box from a zx750A1 /GPZ 750 (1983) and fit KN filters what would I have to do with the breathers coming from the valve assy/air switch and the ones going into the top of the oil pan are these just breathers or are they vacuumed based lines ?
Re: I want to fit Kn filters to a 1983 GPZ 750 A1
10 Mar 2017 18:07 - 10 Mar 2017 18:08
#756376
Be prepared to spend a good deal of time becoming a CV carb expert. Good luck making the engine run as well with pods as it does with the stock air box. Ed
Last edit: 10 Mar 2017 18:08 by 650ed.
  • Nessism
  • Nessism's Avatar
  • Away
10 Mar 2017 18:10
#756377
1) order Dynojet jetting kit. The bike won't run well with pods unless you rejet.
2) delete the air injection system. Tons of info in the archives on what to do.
3) get a small K&N and attach the crankcase breather to it.
The following user(s) said Thank You: GPz550D1, Bargoth
  • TexasKZ
  • TexasKZ's Avatar
10 Mar 2017 18:38
#756381
Why do you want to do this?
  • Nebr_Rex
  • Nebr_Rex's Avatar
11 Mar 2017 04:27
#756400
Nessism wrote: 1) order Dynojet jetting kit. The bike won't run well with pods unless you rejet.
+1
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Conspiracy
  • Conspiracy's Avatar
16 Mar 2017 11:52
#756886
Probably because "pods add like 2HP each right?!"
Novice rider
1976 KZ900
16 Mar 2017 12:24
#756888
Conspiracy wrote: Probably because "pods add like 2HP each right?!"
:laugh: :laugh: :laugh: :laugh:
  • TexasKZ
  • TexasKZ's Avatar
16 Mar 2017 16:53
#756901
3 if you soak them in WD40 first!
