Finally got my KZ400 to start! But........
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Finally got my KZ400 to start! But........
15 Mar 2017 14:35
#756821
No a smaller one but i think you have a basic problem with your carb set up.
Check your pilot and main jet size.
Some picture of your carb environment will help us to solve your problem.
As i say, one picture says more than thousand words.
  • kyan44
  • kyan44's Avatar Topic Author
15 Mar 2017 14:41
#756822
would I have to change both pilot and main jets?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
15 Mar 2017 15:10
#756824
Give us first a status of your jet size,(pics will help).
Go here to check your technical data.
www.kz400.com/TechnicaldataFrameset.html
  • kyan44
16 Mar 2017 12:26
#756889
Here are some pictures. But it starts up again. But this time the RPM rises up to 4000 - 5000. is that bad?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Mar 2017 13:25 - 16 Mar 2017 13:33
#756890
This explain your problem.
You are not using the right carburetors = (2-Stroke Engine)
Your new Mikuni carburetors need a single throttle cable each.
You have to adjust the throttle cable in the 2 in 1 connector that both carb slider bodys are lifting sync when you pull throttle.
I am right with your carb setup?
Last edit: 16 Mar 2017 13:33 by Scirocco.
  • kyan44
16 Mar 2017 14:06 - 16 Mar 2017 14:12
#756891
I do have a 2 in 1 connector throttle cable.Would I have to switch to single cables? I thought we use the 2 in 1 connector cables for the mikuni's? I think the carbs are for 2 stroke engine. It is what other people use on their kz400. Also is there any carb intake manifold rubber boots that fits on the my mikuni vm30's and a kz400? With that high of an RPM could there be an air leak?
Last edit: 16 Mar 2017 14:12 by kyan44.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
16 Mar 2017 14:30
#756892
No,you can go with this setup but you have first adjust the wire length on both carb top adjust screws to get a sync movement and exact gap (passage opening) of the carb slider bodys. (remove the idle adjust screws first for exact bottom adjustment )
Sorry if my poor English knowledge sound strange for you but it is the best explanation i can do for the moment.
Michael
  • kyan44
07 Apr 2017 14:52
#758734
It's been awhile. But I have changed the sparks plug, rode around the block for a bit with no choke. Then I realize that one side of the bike runs lean and the other side of the bike run rich. How could this happen?
