KZ750 LTD Choke - Fast Idle Adjustment
- Irish Yobbo
Re: KZ750 LTD Choke - Fast Idle Adjustment
06 Mar 2017 21:13
I was planning something similar to your rubber tube idea - instead of widening the fast idle arm though, I was thinking of putting an aluminium clip on the throttle pulley to close up the gap. I'll report back on what I come up with.
1981 KZ750 LTD
- Irish Yobbo
06 Mar 2017 23:32
I've uploaded a video to show the issue. In the end I just bent the arm down a little. Since the differrence between nothing and 5000rpm was about 2mm, I couldn't make a bracket accurate enough.
It currently jumps to about 5000rpm if the choke fast idle is engaged now that I've bent it down. That might be too much, but for now I'd prefer that over too little. It's hard to tell how much that will translate to when cold, but if it's too high I can just turn the choke down a little until I adjust it again.
Thanks for your help everyone!
1981 KZ750 LTD
07 Mar 2017 05:02
Sounds like you bent it a little too much. You can use the other slot to bend it back a smig. That's why there are two slots for bending.
- Irish Yobbo
07 Mar 2017 13:04
Actually It's almost perfect. When just started from cold this morning and only on the fast idle it sits a little below 2000rpm.
1981 KZ750 LTD
