VM26 engine side OD?
  • Nessism
  • Nessism's Avatar Topic Author
  • Away
12 Jan 2017 08:21
#752008
Anyone know the outside diameter of the outlet spigot on the VM26 carbs? Where the carbs plug into the rubber carb boots attached to the head? Can someone throw some calipers on a set of spare carbs?
I've got a set of carbs at home that I can measure, but hoping to get the info earlier.
Thanks in advance.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: VM26 engine side OD?
12 Jan 2017 09:13
#752012
If I'm interpreting your question correctly, the OD of the outlet side of a set of VM26SS measure at 34.1 mm.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jan 2017 13:44
#752030
I think the 28 and 26's are the same. Mine are 33.86 mm.
