- Thank you received: 2
tk27 needle replacement
- khungerf
05 Jan 2017 13:12 #751472
by khungerf
-Lee
'84 GPZ550
tk27 needle replacement was created by khungerf
so... looking to find replacement parts for this obsolete carb.
Options;
K&L rebuild kit : problems; reviews say bowl gasket and jets are not good. no needles
Dyno Jet: No o-rings, no pilot jets (only main jest and an adjustable needle)
I have ordered the float bowl gasket, and can get all O rings from partzilla, I can get jets from Jets-R-Us ($9 - $12 each).
Are there any other needles (without spending $140 on dynojet) that will work in the TK27 carbs that have an adjustable clip?
Thanks,
Lee
Options;
Thanks,
Lee
-Lee
'84 GPZ550
- khungerf
08 Jan 2017 09:04 #751691
by khungerf
-Lee
'84 GPZ550
Replied by khungerf on topic tk27 needle replacement
I would think the TK26 needles would work and they have clip positions.
Anybody know?
Anybody know?
-Lee
'84 GPZ550
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
09 Jan 2017 04:47 #751759
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic tk27 needle replacement
TK26 (H Model) and TK27 (A Model) have different vacuum slides, and vacuum slide needles. Not interchangeable. The Dynojet Kits also do not use the same slide needles.
- khungerf
09 Jan 2017 06:50 #751771
by khungerf
This confuses me a little (not always that hard to do) as the dynojet does not appear to have a different slide, only a replacement needle. I am getting that from the parts list on the .pdf that comes with it.
I may have to play with some different needle shapes and/or use washers to adjust the needle.
-Lee
'84 GPZ550
CoreyClough wrote: TK26 (H Model) and TK27 (A Model) have different vacuum slides, and vacuum slide needles. Not interchangeable. The Dynojet Kits also do not use the same slide needles.
-Lee
'84 GPZ550
