Help a newbeginner..
  • Nessism
  • Nessism's Avatar
  • Online
Re: Help a newbeginner..
19 Mar 2017 15:05
#757162
If the idle is creeping up when hot you got a lean condition, possibly leaking air into the rubber boots.
I'm not familiar with those particular carbs but typically the pilot fuel screws on the bottom should be open about 7/8 turn from lightly seated and the pilot air screws, located on the side, should be about double that.
One major issue you may have it jetting. VM24's with a 750 engine is sort of uncharted territory. Only thing I can suggest is to keep experimenting to see what helps and what doesn't. If the stock jetting is a 100 main and you are at 125 it seems to me that you are too rich but I'm not a jetting guy. Typically, when running pods, you need to bump the mains about 4 steps or so. And the pilots should never be bumped more than one size.
If you have the option to install the airbox w/filter and return the jetting to stock I'd start there. You can always move back to pods after you confirm the engine is reliable and well sorted.
Good luck
  • gordone
  • gordone's Avatar Topic Author
20 Mar 2017 11:40
#757233
Nessism wrote: If the idle is creeping up when hot you got a lean condition, possibly leaking air into the rubber boots.
Good luck
I got a advise from a person on Facebook (hehe), he said I could try with some "start gas", spraying around the inlet and the engine should not react on it.
Project:
  • Conspiracy
  • Conspiracy's Avatar
20 Mar 2017 13:18
#757239
I believe he was telling you how to check for vacuum leaks around your intake. Spraying fluid (carb cleaner, brake cleaner, wd-40) around the boots will temporarily block the air leak, which may cause the RPM to drop. If the RPM drops while you're spraying you know you have a leak in the connection point between carbs and engine. A leak there will allow air to be pulled past the carb into the engine creating a lean condition. Lean condition = high RPM
Novice rider
1976 KZ900
  • gordone
20 Mar 2017 15:41
#757248
I`m quite sure he thinked about the gas will increase RPM since it`s start gas, the vaccum will suck in... ?
Project:
  • KZB2 650
  • KZB2 650's Avatar
20 Mar 2017 16:06 - 20 Mar 2017 16:33
#757251
Keep the rs as low as possible to make the most vacuum at the carb/holder when spraying and have read more than a few times on here that will only show a large leak and not a small one but give it a try anyway. And when you take the carbs off to jet em give us a straight on picture of the bowl still on the carbs so if we can see if it has the second pilot screw on the bottom.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 20 Mar 2017 16:33 by KZB2 650.
