Identify Carburetor
  • gordone
  • gordone's Avatar Topic Author
Identify Carburetor
26 Dec 2016 06:53 - 26 Dec 2016 06:58
#750724
Hi,
I have bought a Kawasaki Z 81 model orginal with 650CC, but has been upgraded to 750CC.
I have started to maintaince on the carburetors and want to by some parts, but I have problem to figure out model number so I can search for parts lits... I hope somebody here can help me to idenify them?
Please see attached pictures.
Thank you so much for taking time to help me out with these case.
Project:
Last edit: 26 Dec 2016 06:58 by gordone.
  • Nessism
  • Nessism's Avatar
  • Away
Re: Identify Carburetor
26 Dec 2016 11:47
#750731
Those are Mikuni VM carbs. I'm not sure what size. If you have some calipers you may want to measure the ID on the small end. They should be 24mm or maybe 22mm. VM24's or VM22's. Check the parts fishe for into too. What ever you do please do NOT purchase some junky aftermarket "carb kits". That is the wrong path to putting the carbs right. www.partzilla.com/parts/search/Kawasaki/...ycle/1981/parts.html
26 Dec 2016 12:27
#750732
Take a look at the image below. Ed
Attachment VM22vVM24Carbs-2.jpg not found
  • gordone
28 Dec 2016 07:23
#750812
Thank you verry much for Your inputs ! I will check these when I come home after New year and replay back to you all ! :)
Project:
  • gordone
02 Jan 2017 11:12
#751164
Hi,
Sorry for slow replay, I come home today...
According to the picture you have posted above have I idenified the carb to be VM24, but when I took the measurmenet on the small pipe outpus I have almost 26mm, please see attached pictures?
Are these VM24 ???
Thank you very much for your respons.
Project:
