- Thank you received: 1
Carb Secondary Main Jet Help 1983 kz550 gpz h2
- kosh3rhalal
12 Dec 2016 01:04 #750014
by kosh3rhalal
Replied by kosh3rhalal on topic Carb Secondary Main Jet Help 1983 kz550 gpz h2
wow thanks man, i really appreciate it.. I would have just kept it in there if I knew it was such a difficult part to track down.. But i did research and find out that the #64 slotted jet on tks are also used on certain yamaha scooters and honda as well.. I guess cv carbs were used for a few more years with them, i havent found a 64 yet so your a lifesaver.. same size?! thats a nugget of info ill expand my search
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
12 Dec 2016 04:45 #750017
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic Carb Secondary Main Jet Help 1983 kz550 gpz h2
- Tyrell Corp
- Thank you received: 261
12 Dec 2016 14:43 #750051
by Tyrell Corp
Replied by Tyrell Corp on topic Carb Secondary Main Jet Help 1983 kz550 gpz h2
Sorry ...I looked and they were in an old set of carbs that have gone now. This secondary main is unusual.
There's quite a few options you have with other CV 27 or 30 carbs. The later zr550 had kehin semi-flatslides but the spacing is different.
If you get stuck this guy knows jap carbs really well, he is quite helpful with advice too.
www.nrp-carbs.co.uk/
- kosh3rhalal
15 Dec 2016 11:31 #750241
by kosh3rhalal
believe it or not ppl, but i found a jet from jetsrus that fits.. its a Keihin main jet that i matched up the dimensions and its a slotted head type jet but it has way better surface area to tighten the jet down.. I already have it back in the carb and will test it out once I get the darn carb back on. I also found a company on ebay that has the actual stock slotted jet and ordered as well.. if anyone needs the link just pm
