- Thank you received: 1
Carb Secondary Main Jet Help 1983 kz550 gpz h2
- kosh3rhalal
Need help identifying the secondary jet on my 83 kz550 gpz h2. its a slotted head jet thats stamped as #64. The part is long discontinued by KZ and no one Ive spoke with can ID this jet or locate one! Partzilla lists it as 92063A-1122 JET-MAIN that is screwed over a nozzle. I just finished a carb rebuild and rejetted the carbs with a Dynojet stage 1, and found the previous owner had stripped the slotted head off. I was able to spin the jet out with a reverse drill bit and did not damage the carb but just need this one jet to get the bike running smooth! If anyone knows where I can source this part I would appreciate the help after doing a lot of digging I may be missing it online because of the part name(Main jet? Leak jet?) I included the diagram, the jet is 92063A.. And some pics, thanks guys
- JR
- Thank you received: 449
Once you find manufacturer then you could check jetsrus.com
Kinda looks like one of my Keihin jets which I got from Z1Enterprises. Took a quick look and they dont list a #64. Doesnt necessarily mean they dont carry that size.
I believe Mikuni and Keihin use a different numbering system so same # can mean different sizes between manufacturers.
I know nothing about TK carbs. loudhvx is the resident expert on those
Good luck
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- JR
loudhvx wrote: Thanks, JR. Unfortunately, I don't have any info on those intermediate jets for his TK26 cv carbs.
Ok.
Bummer.
So i just dug out some keihin main jets and measured and get aapox 6.86mm diameter an 8.56 mm length so it looks like TK carbs use something else. TK brand jets.
Try jrtsrus
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
- khungerf
- Thank you received: 2
www.jetsrus.com/a_jets_by_carburetor_typ...eikei_selection.html
-Lee
'84 GPZ550
- loudhvx
khungerf wrote: I am just wanting make sure but these are the jets for all the TK carbs?
Those are mains and pilots for some TK carbs, but they are not showing the jet you need in that link.
1981 KZ550 D1 gpz.
Other links.
- khungerf
My carbs are TK27 and I have not removed them yet to measure the jets.
If I cannot re-jet because of lack of availability I will probably start looking for some replacement carbs.
sorry, if this is a bit of thread-jack, but it seems related.
-Lee
'84 GPZ550
- loudhvx
The ones he is looking for are the intermediate jets. Jets R us does not seem to have them, at least not in that link.
Jets R us might have mains and pilots, but I'm not familiar enough with the TK26 and TK27 carbs to know if those in that link look identical or not.
Regarding TK22 carbs (not for Kz550H or Zx550A):
For the TK22 carbs, it appears Jets R us now have the pilots (I have not yet inspected them), but not exactly in the original stock size 32. The closest they have is 32.5, which should be fine as a standard replacement for stock.
They don't show mains for the TK22's in the stock sizes of 92 and 94, but you can probably get close replacements from Keihin or Dynojet.
Most TK22 rebuild kits have the stock sizes 32 and 92.
1981 KZ550 D1 gpz.
Other links.
- kosh3rhalal
I did a dynojet stage 1 kit, and im trying to keep the stock carbs even though CV carbs are slowly making me go insane.
- CoreyClough
- GPz550 Addiction
EDIT:
As always Ebay Sellers do not always advertise things correctly. Look at these carbs for sale, and ask the seller some questions about them. These might be the "Droids" you are looking for. :woohoo: Idle knob in the middle, and that fact that they are black carbs to me would be an ID that they are TK26. Maybe the seller will remove one of the bowls and add a picture. If it shows a plug cap that covers that secondary jet, you are golden.
- Tyrell Corp
- Thank you received: 261
If so pm your adress and you can have it for free ok.
As above, even if the slot is stuffed it shouldn't affect it's airflow characteristics.
p.s. the 27 and 30 mm carbs are the same size, strange but true. Possibly the 26 too. It seems the Japs have a different way of measuring them.
