LTD 400 Carb to air box boots
- Stevemillermd
26 Nov 2016 17:21 #749008
by Stevemillermd
LTD 400 Carb to air box boots was created by Stevemillermd
Hello I'm a new member and am trying to get my Dad's 79 400 LTD running again. The air box is gone so I fabricated one following this thread
kzrider.com/forum/3-carburetor/599569-custom-air-box-for-kz440
I need to find the air box to carb boots, or something that will work. Most of the rubber hose I have found is a little too stiff to make the slight bend necessary to connect the two
Any help is greatly appreciated
- Nebr_Rex
- Thank you received: 300
26 Nov 2016 17:36 #749012
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic LTD 400 Carb to air box boots
Try Z1Enterprises.com
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Stevemillermd
27 Nov 2016 03:29 #749023
by Stevemillermd
Replied by Stevemillermd on topic LTD 400 Carb to air box boots
Thanks but no luck. I wonder if ducts from another year, engine size, or even different brand of motorcycle would work? There are some on ebay for 1000cc but no dimensions, guess I'll have to contact them.
Thanks again
Thanks again
- diggerdanh
- Thank you received: 89
28 Nov 2016 06:09 #749084
by diggerdanh
Replied by diggerdanh on topic LTD 400 Carb to air box boots
I have seen people use things like Rancho shock boots or radiator hose for carb to airbox boots. You may be able to browse through the selection of radiator hoses from a local auto parts store looking for something that has the correct ID/OD and the approximate bends that you need. Once at home you can then cut it to the lengths that you need.
