- Thank you received: 1
1983 Kz550 Gpz H2 Jetting Help
- kosh3rhalal
06 Nov 2016 14:03 - 06 Nov 2016 14:04 #747426
by kosh3rhalal
1983 Kz550 Gpz H2 Jetting Help was created by kosh3rhalal
greetings,
I have a Gpz getting dialed in, but need help with some jetting issues im having.. Running a stock airbox with Uni Air Filter and Mac Headers and Exaust. Right Now the bike is running lean but starts with no problem.. i messed around with the idle adjustment knob and it ran worse before i took the carbs off. Is anyone out there running a simiar setup? I was thinking to adjust the clip to run richer or possibly adjust air/idle screws? Thanks ya'll
Last edit: 06 Nov 2016 14:04 by kosh3rhalal.
- Thank you received: 1656
07 Nov 2016 05:29 #747469
by martin_csr
Replied by martin_csr on topic 1983 Kz550 Gpz H2 Jetting Help
loudhvx has a motorcycle stuff page with a lot of 550 info, but I'm not sure if he has much info on the cv carburetors. He has a ton of info in regards to the TK22 carbs. see links in the signature at the bottom of his replies.
- loudhvx
- Thank you received: 1616
07 Nov 2016 07:20 #747479
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 1983 Kz550 Gpz H2 Jetting Help
Sorry, I don't have any tips on the TK26 CV carbs, but, I will say, when I put a Mac system on an 81 Gpz 550, with stock motor, airbox, and filter, I did have to upjet the pilot and raise the needle about a half step, otherwise it would run like shit. The Mac seems to flow a lot more at idle and low RPMs, but not so much at high RPMs ( I think I kept the stock main jet).
A Kerker on the other hand could get away with stock pilot and needle, and maybe only needed a slight bump up on the main.
1981 KZ550 D1 gpz.
Other links.
- kosh3rhalal
07 Nov 2016 13:47 #747506
by kosh3rhalal
Replied by kosh3rhalal on topic 1983 Kz550 Gpz H2 Jetting Help
loudhvx,
I think your dead on with raising the main a half step.. I may try one position up and see where im at, the damn EPA pilot cap should be here today and ill put everything back together and see.. Thanks again, your a true master
