Need backup finding 1983 GPZ 550 pilot jet cap
- kosh3rhalal
02 Nov 2016 18:52
Greetings,
trying to get an old gpz running again, pulled off the carbs[ thanks to riturbo and loudhvx] and saw that the plastic cap [ 11012A ] in carb #1 is gone!... does anyone know where to find one? do the K&L carb rebuild kits come with the caps?
Thanks guys
Thanks guys
Re: Need backup finding 1983 GPZ 550 pilot jet cap
03 Nov 2016 05:48 - 03 Nov 2016 05:52
There are a couple of nos caps listed on eebbaayy. part number search = 11012-1244. $12T each.
The K&L carb kit (KL18-2461) at Z1Enterprises doesn't seem to have the plastic pilot cap.
ps: this is a part that could be a good candidate for 3D printing.
Last edit: 03 Nov 2016 05:52 by martin_csr.
The following user(s) said Thank You: kosh3rhalal
03 Nov 2016 06:38 - 03 Nov 2016 06:38martin_csr wrote: There are a couple of nos caps listed on eebbaayy. part number search = 11012-1244. $12T each.
Good sleuthing martin! The parts fishe seems to be messed up regarding the part number for the plug, but you seem to have found it. 3D printing would work assuming the material is not affected by gasoline, or cut one on a lathe. I've seen metal replica pilot plugs for Keihin carbs before but nothing for these carbs.
Last edit: 03 Nov 2016 06:38 by Nessism.
03 Nov 2016 09:05 - 04 Nov 2016 06:31
The part & full part number were easy to find, no special searching required. The cap is shown in the diagram drawing at Partzilla & the full part number is available as well by clicking the part name in the list. Or if you sign in, the full part numbers are automatically listed.
3D printing. I'm pretty sure some of the plastic carburetor caps are polyester which is one of the plastics used in 3D printing. From the chemical compatibility charts I've seen, nylon should be a good choice.
Last edit: 04 Nov 2016 06:31 by martin_csr.
03 Nov 2016 09:50martin_csr wrote: The part & full part number were easy to find, no special searching required. The cap is shown in the diagram drawing at Partzilla & the full part number is available as well by clicking the part name in the list. Or if you sign in, the full part numbers are automatically listed.
3D printing. I'm pretty sure some of the plastic carburetor caps are nylon which is one of the plastics used in 3D printing. From the chemical compatibility charts I've seen, nylon should be a good choice.
My bad, I mixed up 11012 and 11012A.
- kosh3rhalal
03 Nov 2016 10:41
martin_csr! thanks for that find, great idea on the printing.. i actually have some friends that can print, i wonder what material the NOS is?
03 Nov 2016 11:28 - 03 Nov 2016 11:30
I've seen various genuine oem parts that Kawasaki lists as polyester in the diagrams & on the package.
Here's an example: Z750FX genuine pilot Jet Cap new and out of print 11012-1128 (CAP,POLYESTER)
Last edit: 03 Nov 2016 11:30 by martin_csr.
