A reminder about finding air leaks
- Kapahulu
29 Oct 2016 01:09 - 29 Oct 2016 16:59 #746429
by Kapahulu
2strokeworld.com
A reminder about finding air leaks was created by Kapahulu
My KZ900 has had a rough idle for a long time. That and a lack of oomph were the reasons I "found" time to install another set of cylinders bored out to 1015cc. I wasn't sure what the problem was, the intake manifolds are a few years old, dyna ignition timed with a light, carbs cleaned many times.
The carbs I had been running were VM26's from Sudco. I changed out to a set of VM29's that I had sitting around. I cleaned the 29's before installing. Still the same problem with idling. When cold, it didn't want to idle, Adjust the idle speed upwards, then when the motor was warm it would idle too high and still be unsteady. I sprayed WD40 on the carb boots and didn't think there was a problem.
I noticed the #1 carb seemed to cough more than the others and figured I'd change the intake manifold even if it doesn't seem to need it. Pulled the carbs off, started unscrewing the bolt and.... it wasn't tight! Both bolts were a bit loose. Next I removed the manifold, cleaned it along with the head with brake cleaner, dabbed some permatex ultra black then reinstalled the manifold. Next day, started it up and the bike now idles better than it ever has since I bought it!
Lesson: check everything. I was looking for cracks in the intake manifolds, dirty pilot circuits and the problem was two intake manifold bolts that had worked loose or I forgot to tighten them.
2strokeworld.com
Last edit: 29 Oct 2016 16:59 by Kapahulu.
The following user(s) said Thank You: undiablo
- undiablo
- Thank you received: 64
29 Oct 2016 05:07 #746430
by undiablo
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Replied by undiablo on topic A reminder about finding air leaks
Thnaks for sharing! Sometimes the solution is easy as this.
- Thank you received: 2840
29 Oct 2016 05:20 #746431
by Nessism
Replied by Nessism on topic A reminder about finding air leaks
WD-40 or similar on the boots only shows gross leaks. I cringe when people suggest that as a method to diagnose hanging idle or lean running issues issues. KZ boots are relatively inexpensive so it's best to just replace them with new if your bike has the originals.
