VM29 intake boots
- sparkybr74mr
02 Oct 2016 19:59 - 02 Oct 2016 20:16 #744290
by sparkybr74mr
90 FLSTS
11 FLSTF
11 Ural Patrol
76 KZ900
VM29 intake boots was created by sparkybr74mr
I recently aquired a 76 KZ900 with a 78 KZ1000 engine that has VM29 carbs on it, I need to replace the intake boots. Are the intake boots the same as the stock kz intake boots or special order for the carbs.
90 FLSTS
11 FLSTF
11 Ural Patrol
76 KZ900
Last edit: 02 Oct 2016 20:16 by sparkybr74mr.
- Thank you received: 2755
02 Oct 2016 20:48 #744291
by SWest
Replied by SWest on topic VM29 intake boots
The stock ones for the 26-28's will work.
z1parts.net/z1900-kz900-kz1000-manifold-carburetor-holders/
- KZB2 650
- Thank you received: 265
03 Oct 2016 06:35 #744315
by KZB2 650
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Replied by KZB2 650 on topic VM29 intake boots
These are whats needed to put em on the KZ650 too...... the bolt holes just need to be slightly slotted with a dremel or I carefully used a round file...... the ports matched up too which surprised me as I thought the big bikes ports was going to be larger ..... I even took a little sandpaper and opened them up ever so slightly to get em as even as possible..... bought em used way back in 83 so yah they've been shot for a while and I just had to buy new ones too
1978 KZ650 b-2
