Carb Slide Adjustment?
  • johnnymoff
  • johnnymoff's Avatar Topic Author
01 Oct 2016 07:28
#744140
I have VM26s (i think) with the accelerator pump.
What is the adjustment screw in the attached picture for? They don't seem to be all set the same in each of the four carbs.
I know that the needle height is adjusted with the clip. I was wondering if the screw in the picture might be used to affect the moment when the needle starts to rise and unblock the needle jet. I read in my manual that the needle does not start rising out of the needle jet immediately but only after some amount of throttle travel.
I don't think the manual says anything about this.
Thanks
Engine: 77 KZ1000 A1
Frame: 78 KZ1000 B2
Carb Type: VM 26 with accelerator pump.
Needle clip: 3rd (middle) position
Pod air filters
Main Jet 132.5
Idle Jet 20
Clip position on needle 3rd (middle)
Exhaust 4 into 1 Vance and Hines
PO says 1170 kit installed.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Carb Slide Adjustment?
01 Oct 2016 07:32
#744142
That is to sync the carbs with a set of gauges.
  • johnnymoff
01 Oct 2016 08:07
#744149
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Oct 2016 08:17
#744151
YUP Don't try to do it by ear. Bench sync them the fine tune them with the gauges.
  • missionkz
  • missionkz's Avatar
01 Oct 2016 16:22 - 01 Oct 2016 19:05
#744188
Might not be an issue, as you could be aware of it, but you are missing the lock bolt that holds the lift arm to the common throttle shaft. Is it out on purpose or ???
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 01 Oct 2016 19:05 by missionkz.
  • z1kzonly
  • z1kzonly's Avatar
01 Oct 2016 18:38
#744197
when your ready to go back together.
I always used a 1mm .039" piece of copper wire. I used the copper "O ring" wire i used for the cylinder block or you can use a paper clip.
You set all 4 slides the same height.
Put the wire at the back side, bottom of the carb body. Put the wire in like a feeler guage under bottom of slide.
Pull it out and adjust the screw up or down to get a slight drag, pulling it out.
Do all 4 slides the same. This way they are all open the same.
Make sure your idle adjuster screw is turn out.
A lot of babble for this!
Just adjust all 4 slides the same with a piece of wire pulling out with a little drag on it.
This is pre-lim.
At least this is what I did years ago with stock carbs. 26mm 76 carbs are the best stock carbs.
Thats why Kaw changed carbs every year from 72-73 - 74 - 75 28 mm's sucked, were cold blooded. That linkage sucked! I used to glue 2 of those stainless shims together to stiffen up the play between the lift parts.
final will be running and with carb syn vacumn guage's, if you have them.
But Good Luck
  • johnnymoff
01 Oct 2016 23:34
#744229
Thanks everybody!
I bench synced the carbs and adjusted the the floats and she's running a lot better.
I adjusted the slides to have about 1 mm of an opening on the back side and did so with the idle adjustment in the middle of its adjustment range (that seemed to work better than having the idle adjustment all the way out).
-John
Frame: 78 KZ1000 B2
Pod air filters
Main Jet 132.5
Idle Jet 20
