GPZ550 Carbs on KZ550
  • Wildman1024
  • Wildman1024's Avatar Topic Author
29 Sep 2016 16:52
#743962
Do the 26mm GPZ550 carbs for the KZ550? If so is it worth it?
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
  • Nessism
  • Nessism's Avatar
  • Away
  • Wildman1024
Re: GPZ550 Carbs on KZ550
29 Sep 2016 17:10
#743965
Nessism wrote: Define "worth it".
Is it worth "Upgrading" and dealing with whatever needs to be done for an undisclosed amount of power gain?
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
  • Nessism
  • Nessism's Avatar
  • Away
29 Sep 2016 17:29
#743966
I'd say no. It's an old vintage bike, it will never be fast. Most important thing on these bikes (my opinion) is for them to be trouble free and non temperamental.
  • Wildman1024
29 Sep 2016 17:31
#743967
Well I'm not really looking to make it "fast". It just kinda runs like crap now and I gotta pull the carbs off anyways so thought it might be a nice upgrade.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
  • Nerdy
  • Nerdy's Avatar
29 Sep 2016 19:10
#743978
Wildman1024 wrote: Do the 26mm GPZ550 carbs for the KZ550? If so is it worth it?
IIRC the GPzs have other mods (e.g. cams) to go along with the larger carbs. With the standard KZ head and cams, not only will you probably not reap any benefit on the top end, you'll probably lose some grunt on the bottom end.
Having said that, you can probably get it to work. If you're doing it to learn / as a for-the-heck-of-it project, then that's great. If you want to improve a daily rider, you'll get a better result from fixing your existing carbs. Good luck!
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Tyrell Corp
  • Tyrell Corp's Avatar
30 Sep 2016 03:30
#743997
TK26mm are CV carbs, your 81 kz550 uses slide carbs, You would need to chaange the head too if you wanted to use the Cv carbs.
  • loudhvx
  • loudhvx's Avatar
30 Sep 2016 06:54
#744012
Tyrell Corp wrote: TK26mm are CV carbs, your 81 kz550 uses slide carbs, You would need to chaange the head too if you wanted to use the Cv carbs.
Exactly.
The intake carb holders have the mounting bolts set wider on the TK26 carbs, and the intake port is smaller on your engine anyway.
Your Tk22 carbs are going to be much easier and cheaper to tune correctly, and the 81 gpz550 uses those same carbs (with different main jet).
If you haven't already, you can check out the TK22 website link in my signature. It might help get you get them sorted out. (In particular, you may want to check the section about choke flaps).
If you don't already have a manual, there are several in the links. They will help in case the problem turns out to be something other than carbs. If you start to suspect valve adjustments, read the valve train warning before opening the valve cover.
  • Wildman1024
30 Sep 2016 16:53
#744071
Thanks for the help guys. I'll just go through the carbs I have. Put 123 miles on the bike tonight and it runs great once warm. It's just the getting it warm part that sucks.
78 Kawasaki KZ650B
1973 Yamaha RD350
1983 Honda CB1100F
